Go to solution Solved
Is my tv AirPlay compatible
(Topic created on: 25-04-2023 10:22 PM)
Lozzer1
Just bought a UE55MU7000T Samsung tv. Been trying to look for AirPlay but can’t seem to find. Does it have it or not?
JAMES4578
Samsung Members Star ★★
Hi @Lozzer1 May I ask  where  you purchased this TV?   The reason I am asking  is that MU  models were released in 2017,would not have thought many places  would be selling this model. https://www.samsung.com/uk/support/model/UE55MU7000TXZG/
Airplay is only compatible with Samsung Tv's from 2018  onwards.    Some information here https://www.techradar.com/how-to/airplay-on-samsung-tv
One Ui 5.1,Android 13 .
8 REPLIES 8
DarkScouser2002
It should be in the connections setting within the TV. Settings > Connections > Apple AirPlay settings
Lozzer1
There is no connection setting
DarkScouser2002
Hmm might be different, should be eithin the connection settings, sub settings of the likes of wifi and that
JAMES4578
Lozzer1
Picked it up as an ex demo
thanks for your answer James
JAMES4578
oh right,thanks for explaining Lozzer.  Hopefully you still get enjoyment from the TV.
Lozzer1
Thank you
yea just an extra step to get casting is a bit of a pain, otherwise can’t complain
JAMES4578
Yes know not ideal but as long as impressed enough otherwise.
