29-11-2021 07:33 PM in
TVJust bought the 2021 frame 32 inch. Wanting a white bezel but the new frame bezel site only has ‘ afternoon tea ‘! A sort of light cream colour . Does anyone know if the 2020 bezels are compatible with the 2021 tv’s ? Thanks in advance 🤞
Solved! Go to Solution.
29-11-2021 07:53 PM in
TVHey @MadGreek1977! The 2020 bezels aren't compatible with the 2021 Frame, as the design is different. Hope this helps 🙂
29-11-2021 08:15 PM in
TVThank you , fingers crossed for a white 2021 soon !
