HELP WITH HAYU APP
(Topic created on: 14-08-2020 11:28 AM)
KATE50
Tags (1)
3 REPLIES 3
Fourreals
I am having the same problem too. Samsung what’s up wit dat!?
Bromo
Not knowing where you live, but I believe it is outside the UK or AU if you don’t see the app.
https://support.hayu.com/hayuArticle?id=kA0240000009pRtCAI&q=devices
my issue as well.  It’s suggest to reset your tv and use the support regional setting or use a complex method of downloading the app, and running it in dev mode.
or get a Roku/Firestick/Android set top box
NRD80Y
I have QA43LS03TAWXXY and QA65Q9FAM and also not able to find Hayu app
