Go to solution Solved
DRM on HDD PVR varning when shift from 40" to 55" Samsung TV in my house.
(Topic created on: 13-08-2020 04:53 PM)
svenne12
When I changed a HDD pvr recording from my 40" Samsung TV to my new 55" Samsung QLED TV I got no access.
There was av warning. Contains DRM protected material.
Is it only possible to see on my 40" TV where the recording was done?
AndrewL
@svenne12: I have had a look into this for you and can confirm that recordings are DRM-protected and therefore cannot be played back on a computer or on a different TV. Apologies for any inconvenience this may cause you.
2 REPLIES 2
AndrewL
Tony H
Even if the other TV is exactly the same model as the first does this rule still apply?
