Help fix my Tv, it is showing horizontal and vertical lines
(Topic created on: 31-07-2024 11:10 AM)
Jazmai
My smart Samsung TV is showing lines on the screen, how can I fix it
1 REPLY 1
JAMES4578
Samsung Members Star ★★
Hi  @Jazmai    Which model do you have and how long have you owned the set? check that you have the latest software.  if the lines are permanent  adviseable to   disconnect external  devices and reconnect to see if that makes a difference, could try a  Factory Reset.
However if there is an error in the picture Test ,Support- Device Care-Self Diagnosis -Picture  Test,it really does need an inspection and likely a Repair  if worthwhile.
