Go to solution Solved
Headphones for Q90T tv
(Topic created on: 04-02-2022 02:11 PM)
Kev7
Hi,
I have a Q90T 55" tv and I'm wanting to connect headphones for watching films.
I know there's no headphones jack, and I'm asking what is the best method to use.
I've tried a cheap DAC from Amazon UK which connected to the digital optical port, but the lag was terrible, I couldn't sync voice and picture.
I've thought about bluetooth headphones, but I read that these also have a lag.
Does anyone have a solution that works without lag / syncing issues ?
Can you recommend me some products to try please ?
I'd prefer to use my wired headphones, but will buy some Bluetooth headphones if you think that's the best option.
Kind Regards,
Kev.
Kev7
Cheers Steve,
I've found out that I can use the Smart Things app on my Samsung Galaxy S8 phone to send the sound from my tv to my phone.
I plug my headphones in to the phone, it has a headphones input.  I can listen without lag.
When I upgrade my phone to one without a headphones input I'll buy one of the cables you suggested, as the other end looks like a mini usb for use with a phone.
Kind Regards,
Kev
4 REPLIES 4
xSteveuk
Mastermind
Hi,
If you have no headphones
Jack
You would need an adapter
Make sure it's samsung
Kev7
Thanks Steve, I have a couple of questions please :
- in the picture you posted, I can see the female headphones end, but what is the other end ?
- is this what you use, without any lag issues ?
Kind Regards
Kev.
xSteveuk
Mastermind
One side is to plug your Headphones jack into the other plugs into the TV
Kev7
Cheers Steve,
Kind Regards,
Kev
