Go to solution Solved
Freestyle portable battery
(Topic created on: 11-04-2022 02:37 PM)
zami90
Hi,
I am looking for a portable battery which is compatible with the projector. The Freestyle is compatible with external batteries that are USB-PD and 50W/20V output or above. Can anyone recommend one? So far I am unable unable to buy the battery base in the UK as it is not for sale. Chat with Samsung has been least helpful.
Thanks,
Zara
The Freestyle
AVNP01
4 REPLIES 4
AVNP01
AVNP01
It's not to expensive especially because it outputs 65watts
zami90
Thank you! Have you tried it? The most current reviews aren't too good.
PlsHlp
Don’t buy the Samsung Freestyle Battery whatever you do. Read the reviews it’s a complete disaster.
I purchased one just over 12 months ago. Like many people it’s only had very limited use, couple of times at most. Won’t charge at all.
I contacted Samsung yesterday for some support. After a frustrating wait and further discussion, Samsungs advice was to buy a new one, currently it has 43 negative reviews out of 50!
Come on Samsung source an alternative and send a new product or voucher out to all us dissatisfied customers, get the confidence back with your valued customers.
