Firmware 1409 Vs 1406
(Topic created on: 30-09-2023 07:44 AM)
KAKUL
To the Samsung support team
The updated version was 1409 last year
The new version is update 1406
T-MSLUABC_1406.3
It is not possible to update to this version now
18 REPLIES 18
Ginga_p
Hotshot
Not the first device this happened to, the qe65qn95 has had same thing and another couple of devices reported. They do realise just takes awhile.
G G
Ronnoc69
I would also like to know why the downgrade in Firware version?
AntS
Hi @KAKUL ,
What's the full model number of your TV? And which country are you based in?
Ronnoc69
Hi Ant
I am in South Africa and TV is 82" Q60R QLED Smart 4K UHD TV
I am also on 1409 firmware and even tried the new 1406.4 on a USB but said no update, obviously due to lower version no.
Thanks
AntS
Cheers @Ronnoc69
The firmware releases differ depending on the region/country (e.g. the links to the firmware downloads I posted in those topics should only be applicable to European sets), so it's best to get in touch with your local Samsung Support for further advice: https://www.samsung.com/za/info/contactus/
Ronnoc69
Thanks Ant
KAKUL
Hi Ants
RU7100
T-MSLUABC
Levant
AntS
Cheers @KAKUL!
Same as for Ronnoc69 would apply for you too: it's best to get in touch with your local Samsung Support. Samsung Levant's details are here: https://www.samsung.com/levant/support/ , and if you're located in another country in the Middle East not covered by that then you'll be able to find a link to that country's Samsung site and Support contact details from the global list here: https://www.samsung.com/uk/function/ipredirection/ipredirectionLocalList/
