Factory Reset Impossible
(Topic created on: 08-01-2023 10:20 AM)
Members_CwviKF0
I have a QLED 8K QE65Q950R tv, I need to carry out a factory reset, but unable to do so! The TV will no longer except the PIN code [0000 or 1111]  I have tried to do a manual reset by disconnecting the power supply and pressing the manual standby switch under the TV and then reconnecting the power supply and holding down the manual power switch for 15 seconds. This does not work either! Please, please can you help in this matter??
BR, Howard Minchin
1 REPLY 1
AndrewL
@Members_CwviKF0: In this instance, please follow the link below, click on 'How to reset the PIN' and follow the guide to restore the default PIN of '0000'.
https://www.samsung.com/uk/support/tv-audio-video/how-to-find-your-pin-code/
