Go to solution Solved
Error Code 107
(Topic created on: 15-05-2020 03:50 PM)
Dennis35
What does error code 107 meanon my Samsung UE55RU700K. I watch a film on Amazon and when it finishes i can`t get wi-fi because of error code 107
Dennis35
Hi Tess,
Just to make sure you receive this text I shall repeat it
My model is UE55RU700KXXU i think the problem was windows updating times so I have changed the updaye times to 00:00 - 0800
50 REPLIES 50
TessM
Mastermind
Hey @Dennis35 ,
In Samsung TVs the error code 107 indicates issues with the Internet, without which a smart hub cannot work. Do you have any other devices connected to this network and is this only happening when you are using this app?
We would also like you to ensure that the TV is running on the latest version available. To do this, can you double-check the model code and provide us with it here as we are unable to find this model on our page. This can be found at the back on a white sticker.
Dennis35
Hi Tess,
FlorieJoy
Samsung Helper
This is super hepful thank you
ParkerJack
Model UN65RU7100F. all issues with the router has been checked and are working, however I am still gettting this error code.
Naiel
UA55RU7400KXQR
Naiel
I have error code 107, how to fix it out!??
Gordon9
Has anyone figured out how to resolve this problem
Biscitt
So how I fixed this I opened the settings and went to
General -> Network -> Reset Network Settings and just reset it and reconnect to you’re WiFi.
yoboy55
hi my tv also has problems connecting or detecting wifi here is my model number
MODEL UA55RU7300GXXP
version CA02/URU7300
