Easy Connection to Screen is not working QE65Q70A
(Topic created on: 07-12-2021 03:32 PM)
kmeral
I am on the same network using 5gHz Wifi,
i have upgraded my tv to latest v1808.1,
i shut down all firewall and antivirus stuff
BUT i still cannot connect to TV
Does anyone know any solution?
4 REPLIES 4
xSteveuk
Mastermind
Hi,
This page maybe helpful
Samsung TV won't find or connect to my Wi-Fi network
https://www.samsung.com/us/support/troubleshooting/TSG01111046/
rogersdave77
Troubleshooter
You need to use Google home app...Samsung no longer support easy connection
jeterubin
Google Home does not allow to share laptop screen in TV. Please, Does anybody knows an app for this purpose witch work properly? Thanks in advance
RobPoffo
Maybe this is not the same problem you are facing. My computer has two internet access: one wireless and another cable ethernet.
I realized that the ethernet connection was causing issues to the TV to connect to my computer. When I turned off the ethernet connection, it accepted the connection using the wifi.
TV and computer are on the same Wi-Fi network right now, working as expected.
