Go to solution Solved
Developer Mode removed on latest Samsung TVs
(Topic created on: 21-10-2024 08:12 PM)
MonkeyKing
I have the Samsung TV s95c, upgraded to the latest firmware (2013) OneUI today and developer mode is no longer accessible
Is there a way to access Developer Mode?
MonkeyKing
Found the solution
From the Apps selection, at the bottom is 'App Settings, then you can enter 12345
8 REPLIES 8
lminvti
Samsung Members Star ★
Hi there, have you tried open settings then go smart hub click apps then enter 12345 as default pin and then look for toggled to turn on developer option. Or Enter the app settings. Here, press the 12345 on your remote and type in the 12345 passcode again if asked. This brought up the developer mode options
MonkeyKing
Hi, there is not an option for smart hub or apps on the new firmware
MonkeyKing
MonkeyKing
Found the solution
lminvti
Yes that's what i said in my comment or enter app settings 😊
GMC12392
Samsung smart tv 55inch
AdamGamin
where did u find the apps and apps settings
AdamGamin
nvm i found it i was just blind
