Constantly having to retune tv - channel loss
(Topic created on: 19-09-2020 03:17 PM)
Jamesgreen1994
Hi All
I have a Samsung UE50NU7470 TV. Every few days I go to switch the tv back on and all my tv channels have disappeared. On the TV guide it says no information and then I have to manually re tune the tv to find all the channels and store them.
This happens every few days after watching the tv daily. I’m tuning the tv to “Freesat” on the tuning options.
Thanks
James
18 REPLIES 18
DeeLW
Can I ask, did you have a Sky Q satellite dish? I haven't been able to add any channels from my Freesat Humax.
Jamesgreen1994
No just have a normal free sat dish. Only happens with this tv all other TVs on the dish are fine.
Bernie9
I have recently bought the 50" and this has happened twice within a week.  It's using a normal sat dish.
Boidy
I'm having this issue too on a new 49" QLED model. I can replicate the fault by  going to the Samsung TV app. Once this app launches and starts to play back content, all freesat tunings option are lost, in fact it looks as if the entire satellite tuning module crashes. If I go to the setup menu and go to broadcasting, all options are greyed out and I need to factory reset the TV to restore it and go through the tuning process again.
Ratters
can I ask if you ever got this sorted as mine is doing exactly the same, broadcast menu is greyed out, it seems if you watch Samsung TV/TV Plus channel, the EPG switches over to that and you lose Freesat 🤔 thanks in advance 👍
Boidy
No. Still doing it. Had the TV replaced under warranty and it still does it so clearly a
firmware issue.
Ratters
thanks for letting me know, I've found how to ungrey the menus by placing the channel to live, so now I can re-setup the channels, cheers
Matt C
Thank you Boidy so much! I've been getting this problem intermittently since I bought this TV nine months ago, but I could not replicate the problem on demand. I had previously contacted their chat support and been advised to seek help from a satellite engineer. I have now a shiny new dish with the same problem on my TV and £200 less in my bank! Thanks to your repeatable error I have just told Samsung Chat Support the exact problem again, referencing this thread and your reply specifically. (I don't even use the Samsung TV app, so perhaps other apps cause the problem as well, nevertheless they have to fix it now). Their reply "Thank you. As I've reported this matter to our product specialist, we are processing an advanced update for this TV model about this issue so it will be fixed immediately. We don't have the exact time frame of the update but don't worry, this update will not take that long."
Terry O
Hi people. Appreciate this thread was started 2 years ago, but I have an NU750049 which I’ve just started using with FreeSat and on coming back from standby it drops a number of channels & always needs a retune.
Seems to have trouble remembering the channel list when in low power state. Have tried all the obvious suggestions, but no luck solving the problem as yet.
Did any of you get this problem FreeSat resolved?
Curious to see if anyone else has a fix that I may have missed.
Thanks.
