Cannot turn off my Q7F with remote control
(Topic created on: 04-12-2018 02:18 PM)
mehdi6
Hello
I have a Q7F 55" . Everything works perfect, except that I can't turn it off with remote control! I have to turn off the TV by the physical button under the Samsing logo.
I have tried these all:
* Changed the batteries
* Reset the TV
* Updated the TV firmware
* Reset and re-paired the remote
I also have a Samsung soundbar, and to make sure there is no interference, I disconnected and turned off the soundbar and its remote control.
I tested the remote control with another Q7F and it can turn it off!
Is there anything else I should do to make sure the TV (or its control box) is defective?
Thank you
2 REPLIES 2
CarlH
Maestro
Hi @mehdi6. If the remote is working with the other features on your TV, it could be the IR that's the issue. Do you have a spare/ standard remote that came ith your TV that you could try out?
mehdi6
Unfortunately not. Based on what I've tried so far, it seems there's a problem with the black control box. Can you think of anything else?
