can't update firmware samsung q90R
(Topic created on: 24-09-2019 06:33 PM)
DReborn
i have a new samsung q90r 82" and i cannot update the firmware. i have tried wifi and wired connection. i have done a factory reset.
start the update
tv finds the update
tries to install it and eventually timing out giving me the CURL28 internet unstable error (i have a dedicated 1gig/1gig internet and all my devices are working great)
anybody been successful in updating the firmware on this tv?
7 REPLIES 7
JAMES4578
Samsung Members Star ★★
start the update
tv finds the update
Hi @DReborn I take it streaming services are fine on the TV- just issue with update.     It is possible you have the latest firmware which is 1318.0, however if not you could download it to  USB and and update that way . However it seems the 82 inch model is an US one and not available in Europe.    https://www.samsung.com/us/support
If by any chance there is problem with any of the apps  an idea is to change the DNS settings. Go to Network-Network Settings-DNS Settings. Change from Automatic to to 8.8.8.8 or 8.8.4.4.
DReborn
thanks for sending! worried to install firmware that is not made directly for my US tv
also, odd thing i noticed: i connected tv to my phone hot spot and the update started to work.....problem is it literally would take 4 hours to download the update
so there is something going on with my firewall/network/etc cause my phone somehow let samsung to start downloading update
JAMES4578
I did send link for Us site but can not see firmware listed there, though is on uk site (there can be differences and generally not recommended to use European ones for US)   It does seem  a bit strange thoughg may be  issue with network, suggestion would be  to reboot router and  [possibly also Tv to see if that makes a difference. Samsung Us Community is here should you wish to look there at any time  https://us.community.samsung.com/
J_K
I switched my connection from wired to wireless, just for the update.  Switched back to wired after update.  It worked.  Not sure why, annoying, but that did it.
conerlyg
Same issue and same fix for 40 series. Except I went from wireless to wired and back again. Samsung. ....weird stuff. get it together.
StyxHunter
THX for this threah, it was helpfull for me
JAMES4578
Glad the advice posted here was beneficial, hopefully you are sorted.
