Can not get Smart Remote to send IR codes for volume up/down
(Topic created on: 18-11-2020 02:18 PM)
Simmarn
Hi!
I have a 2020 The Frame TV with OneConnect box. I want my Smart Remote to send volume up/down to my NAD AMP1 amplifier, but I can not get IR to work on the Smart Remote. IR is just sent from the OneConnect box. How can I get the Smart Remote to send IR codes?
BR,
-Martin
3 REPLIES 3
Pugs1957
SuperStar
AFAIK Smart Remote doesn't support IR. Support for external devices is via HDMI ARC CEC only.
Simmarn
Are you sure? Smart Remote send IR codes at power on/off. Why not support for e.g. volume buttons?
