Error SID_no_signal
(Topic created on: 18-11-2020 02:47 PM)
Gk1231
We turned on the TV yesterday and this page displayed. We have spoken to Samsung, tried to hard reset it but it won't allow us did to saying in correct pin. We have also tried all the normally thing like unplugging and powering down for a few hours etc
The only thing that can be brought up is the settings menu bit even some of those options are greyed out. As well as the general setting freezes when selected.
Had any one encountered this before ? We believe it as something to do with the internet connection and have swapped out the ethernet cable but that hasn't worked either.
Please help if you have any ideas ?
15 REPLIES 15
DUMITRU79
Troubleshooter
You could reset it by going into service menu .
1. power off your TV
2. info + settings + mute + power in a quick sequence.
3 . you'll get this picture
DUMITRU79
Troubleshooter
Then press on "option" and you'll get a sub -menu like this :
Click on "factory reset " , but , do not change anything else .
Gk1231
Thank you, we have tried this and still comes up with the same screen
DUMITRU79
Troubleshooter
Any failed attempts to update software by any chance ?
DUMITRU79
Troubleshooter
....does it do like that on every SOURCE input ?
Gk1231
Won't let me change the source and it failed to update
DUMITRU79
Troubleshooter
Then i think you should consider taking it to a service . Any warranty ? Or is an older TV ?
DUMITRU79
Troubleshooter
I came across this thread on the web . Maybe it'll work for you as well
http://knowledgebase.engagephd.com/article/samsung-ssp-d-e-series-factory-reset-steps/
Gk1231
Thank you for your help, it hasn't worked unfortunately.
We have a back up tv and we are sending it away to get repaired under warranty hopefully.
