Go to solution Solved
Bluetooth headphones for Samsung UE50KU6000
(Topic created on: 09-02-2017 06:31 PM)
stevensben
Can you connect bluetooth headphones to the Samsung UE50KU6000? Or do you need some sort of adapter? I'm thinking about buying the tv but I like to watch movies later in the evening and don't want to disturb everyone. Thank you :smiling-face:
KellyM
Helping Hand
Hello and welcome, @stevensben,
The KU6000 does not feature Bluetooth, so can't be used with Bluetooth headphones. If you're looking for a UHD TV with Bluetooth, be sure to look at models KU6400 and above. :robothappy:
1 REPLY 1
KellyM
Helping Hand
