Auto Motion Plus settings?
(Topic created on: 06-10-2021 10:23 AM)
magneman
Hi,
I not too long ago purchased a 65" Q95T TV, and I like it so far.
I will mainly be watching TV shows on Netflix - I assume that the soap opera effect is caused by having Auto Motion Plus setting on the TV turned on.
For me, I have the following settings available to customize:
Picture of settings
Also I have another option to turn on/off Noise Reduction (I couldn't find a picture online that also had this setting).
I am wondering, would it be best for me to turn everything off (Blur reduction, Judder Reduction, LED Clear Motion, and Noise Reduction)? Or should I tweek them a bit instead?
Motion feels smooth with everything set to Auto, but it sometimes causes distortion or blurry images which is a bit annoying (have also noticed some weird lighting effects, but I am unsure which of the Auto Motion Plus settings is causing this).
0 REPLIES 0
