Audio reverse channel - PCM only 3-channel? Dolby Digital option greyed out?
(Topic created on: 10-11-2019 10:19 AM)
hulster
On my new Q85 I am having issues with the reverse channel.
1.    PCM - seems only to have 3-channel out. My AV clearly detects that. It is both the same using HDMI or optical out.
2.   I can't choose Dolby Digital as out (which should solve the issue). Even the description says only for Dolby Digitial "+" eARC is needed.
Am I doing anything wrong?
The idea buying the Q85 was to use the Smart TV for 4K content, as there is not a lot available despite Blu-ray. But I am keen on full surround. Not more then 5.1 needed. But that at least.
So currently SmartTV would be useless for me.
2 REPLIES 2
AndrewL
@hulster: Please can you confirm the full model number of the TV, and the external device you're attempting to connect, and I will look into this further for you. Please be aware that the Dolby Digital+ option is only available via HDMI (ARC) for external devices that support the format, and can be accessed by going to Home > Settings > Sound > Expert Settings.
hulster
It's a GQ75Q85R. Partially the prob has been resolved. The issue seems to be DD is only a choice when  a source/film with DD as available sound format has been started. I tried always upfront as a standard setting.
After taking the choice first time it seems to make this the std option if available in a source.
STILL when I switch to PCM I only get 3 channel output.
The AV is a Yamaha RX-S600, ARC (not eARC), 4K/UHD pass through.
