Go to solution Solved
Annoying icon stuck on TV UE40
(Topic created on: 26-08-2017 07:28 PM)
A cust - not happy
Hi
Please HELP
Recently bought new Samsung UE40MU6400U. Since this morning, an icon appears on right side of the screen saying 4000.
Can anyone help getting rid of the same.
Thanks
Wyndstorn
Hello. I copy/paste my response to another post stating the same problem:
I experience the same in a model UE40MU6405.
I've seen that only happens when the TV is turned on by an external device through HDMI CEC.
It seems to be Samsung's TV+ channel number and I can remove it by changing to TV+ and changing the channel, for example to 4001. After this, the message changes to show momentarily the new channel, and then it dissapears.
I think that a firmware update will be needed to solve this problem.
6 REPLIES 6
KellyM
Helping Hand
Hey @A cust - not happy,
Can you provide a photo of this? Does it appear on all channels and sources?
Wyndstorn
Jaydorff
Same issue on my brand new Samsung - your suggestion solved the issue - upgrade required to permanently solve
Virgo47
I have similar issue with brand new Samsung TV UE50MU6172 (probably like UE50MU6170, just for our market) and Blu-ray player Samsung BD-E6100 (I guess from 2012). Today it suddenly started to blink with "Not available" message that I knew is blu-ray's response to not applicable command. Later it kept switching selection in DVD menu. First I disabled all my remotes (battery out), but it did not stop. Then any reasonable action on TV remote helped.
Later I even found out how to initiate this kind of loop. All I have to do with my player is use TV remote - press Home and then Back. I can stop the "Not available" blinking pressing some direction on the remote's wheel. When I disabled Blu-ray player's setting for Anynet+ HDMI-CEC it stopped doing this - so it's definitely issue here, something between the player and TV. Both devices are updated.
SimonF1
Its the same here, ***** stupid banner constantly on my screen. I can tell you one thing and that is i will never buy another Samsung TV, Who in that company thought this stupid banner would be good, Its going to cost them customers, its ridiculous. is shouldnt matter if i want to use ext,hdmi,pc,TV it should not be there.
Anwar_or
Ich habe das Problem auch kann jemand helfen bitte
