Go to solution Solved
Ambient mode routines
(Topic created on: 19-03-2021 07:36 AM)
filipjandora
Hi,
recently I bought Samsung Frame TV (2020)  QE65LS03T. In some videos I have seen that you are able to set routines for ambient mode (e. g. show in scheduled time), but I am not able to find it in ambient mode settings.
Is it forbidden for Frame TV or I am missing something?
Thanks for replies.
Tags (3)
filipjandora
Hi,
I expected to be there, because it was on some video. I managed to figured it out by using SmartThings App. You can set Ambient mode routines by using Routines and Scenes section. There is an option to manage your Ambient mode when you are setting scene on your TV.
3 REPLIES 3
AndrewL
@filipjandora: If you press the Ambient Mode button on your remote to access the Ambient Mode Home Screen, then the Routine option should be visible in the Content Categories along the bottom of the display. For further guidance, please check out pages 49-50 of the user manual via the link below.
https://downloadcenter.samsung.com/content/UM/202011/20201116125257232/NIKDVBADT-3.0.8_EM_NIKE_ASIA_...
filipjandora
Hi,
Grendizerus
is it possible to set Ambiant mode to start when the TV source is inactive? My PC is connected to the TV as a source. So when my computer goes to sleep there's a screen on my TV saying "check source". Instead of that, I'd like to Ambiant Mode to start, just as a screensaver on a computer...
3d animator
