65" MU8000 - PS4 only displaying 1080 Resolution - not HDR?
(Topic created on: 18-07-2017 09:17 PM)
Davinci
I understand you need a new PS4 Pro to get full, 4k support on the playstation, however I know it is also possible on the current firmware to get Ultra HD or HDR on the regular Playstation higher than 1080 - 2k is supported (although games do not support it, Netflix and some Youtube would - I know pointless as built into this TV, but I like to test things 🙂
I have HDR enabled on the Playstation and ensured I purchased High Speed Premuim HDMI cables that are certified, yet it says HDR TV not present and the resolution set is 1080p.
Any ideas from the wise people out there?
Thanks
1 REPLY 1
patrickt
In the setting of the tv, you have to enable UHD color to the hmdi ports.
