43q65c Wall mount bolts/screws
(Topic created on: 18-11-2023 04:42 PM)
Simontzar
Can anyone advise which bolts/screws to use to mount the TV to the wall please? And which length also. Thanks
3 REPLIES 3
mikeoxman
Go to b+q and get some 60 - 80mm bolts with a hex head I just got these 80mm ones but mounting a very heavy 75 inch tv so i wanted pure overkill .. usually some will be supplied when u buy a bracket though.... 20231118_182745_1834_1700332065.jpg
Simontzar
Thanks for the info Mike but ice a feeling the size bolts you suggest nay be to long as the 43q65c is very slim. I've a feeling the bolts should be M8 but can't find no where what length.
mikeoxman
Probs wouldn't go any less than 50mm .. the reason I went with the 80mm ones though was because it seems as If there's an inch of cement on our wall before the drill bit hit any brick ...
