bolts nuts screws for UE50JU6870
(Topic created on: 08-11-2020 09:06 AM)
Uzilara
Which bolts-nuts-screws do you need to use,  to hang / attach a UE50JU6870 TV system to a wall-mount system ...
And where can I find / buy them
1 REPLY 1
ozzie2410
It all depends on a number of things, the weight of you tv, what type of background are you fastening it to i.e. brickwork or lightweight block or maybe a stud wall. This needs to be looked into before you attempt hanging your tv.
