120hz not working on QN95A
(Topic created on: 25-10-2021 03:37 PM)
kazzup112
TV
My ps5 won't run games 120hz any know how to fix?
2 REPLIES 2
St3chn0
TV
Check the following
correct cables are you using the included cable, is this passing through any other source I.e soundbar?
Are you connected to the right port on the TV. Not all ports support 120hz
Have you set the ps5 up correctly?
Ginga_p
Helping Hand
TV
Loads of people are having trouble with the one connect box dont know if theres different versions but some people seem to have problems and some are fine. Same with connecting to sky Q some people are connecting instantly and some not at all. Customer (i dont) were very unhelpful but theres loads of posts about it
G G
