Connection problem with Samsung Galaxy Tab a 10.1 LTE 2019 UK version
(Topic created on: 10-02-2020 08:44 PM)
Angelo005
Hello all,
I have a connection problem!
I have a Samsung Galaxy Tab A10.1, SM–T515, 32gb, 2019. Uk
Default Connection for this tab is: WLAN: WI-FI 802.11a/b/g/n/ac, dual band, WIFI Direct, hotspot.
I believe it's not performing at the network speed n/ac.
My mobile phone: Samsung Galaxy S7, shows a much faster connection speed, eg, network speed; 866Mbps. My Samsung Galaxy Tab A 10.1 is only showing speeds at 433Mbps! The Tabs connections speed should be the same as the mobile!
Please help me resolve this.
Thank you
1 REPLY 1
CarloL
Hotshot
Hey @Angelo005! Are you connecting and using your tablet while other devices are connected to the same Wi-Fi? This may affect the performance of the connection of your tablet and slow it down a bit. Also, go into: Settings > Connections > Wi-Fi > Toggle Wi-Fi on > Advanced > Manage networks > Delete the network, restart the tablet and try reconnecting it to your Wi-Fi again.
