Washing Machine Start Command
(Topic created on: 17-09-2020 08:51 AM)
BarringtonK
Anyone managed to get their washer to start either from the SmartThings app (with one click) or IFTTT with one action?
It looks like when the device goes to 'sleep' mode, the usual 'start' command will not wake it up and get it working. I contacted support and they said that sleep mode was a solution to save money... no kidding... I can't get it to switch on!
Anyone found a solution?
12 REPLIES 12
BarringtonK
I believe the old Samsung app is:
https://play.google.com/store/apps/details?id=com.samsung.smarthome (or similar in the Apple store)
However you should probably use the SmartThings app for now.
Barry
BarringtonK
I think my machine is to old for this functionality. Pressing and holding the smart button, while on has no effect. Pressing and holding the smart button while off beeps but with no change of status
JemimaP
I am having this problem too! Did you work it out?
