edge settings
(Topic created on: 27-10-2020 06:55 PM)
tester87
Since updating my edge lighting setting has disappeared and now I can't change it anyone else experience this I have a s20+
4 REPLIES 4
Beno86
it has moved to the notifications settings..inside of brief pop up settings..hope this helped.
Mikeeb83
I have noticed they have moved it like Beno86 said but mines doesn't work even when setting up the preview doesn't work right 🤔
Aumeisters
Pathfinder
mine works only for Facebook dual secondary account and only if phone is unlock and im using it
MartynaK
Beta Moderator
Beta Moderator
@tester87,
The edge lighting setting didn't disappear! 😉 You can find it here: Settings > Notifications > Set notifications as brief > Brief pop-up settings > Edge lighting style.
