What are you going to do to fix this issue of call recording Samsung
(Topic created on: a month ago)
KaneMcCarthy
Pioneer
CRITICAL DEMAND: UNIVERSAL ENABLE/DISABLE TOGGLE FOR CALL RECORDING
​This is about USER CHOICE. We demand the option to DISABLE or ENABLE the feature at will, not permanent removal.
​The current UI forces the record button on-screen, causing accidental activation via face/cheek touch. This creates a severe legal risk (GDPR/Consent) for thousands of users globally.
​Why Samsung MUST fix this: iPhones (iOS 18.1+) provide a clear ENABLE/DISABLE toggle in Settings that hides the button entirely when disabled. If Apple respects user choice, Samsung must too.
​MANDATORY FIX: Provide a global ENABLE/DISABLE option in Phone Settings that removes/restores the in-call record button. This must be deployed via software updates on all devices running One UI 7, One UI 8, and all future versions. This fix is mandatory for EVERY SINGLE CURRENT AND FUTURE SAMSUNG DEVICE worldwide.
​WE DEMAND THIS FIX BE TREATED AS A HIGH-PRIORITY, SYSTEM-WIDE POLICY CHANGE AND EXPECT A RESPONSE.
3 REPLIES 3
KaneMcCarthy
Pioneer
This is exactly what Samsung should be doing giving us the option1758923473063.jpg
markw93
They ain't checking this anymore as the Beta is over
MartynaK
Beta Moderator
Beta Moderator
Hi @KaneMcCarthy,
Thank you for sharing your detailed feedback. Your suggestion regarding a global enable/disable toggle for call recording has been forwarded to the relevant department 😊. I also recommend submitting it via the Samsung Members app to help increase its visibility.
