Power saving
(Topic created on: 25-10-2023 09:58 AM)
spikey1
Navigator
Is it possible to exclude some apps with power saving turned on? As I need to have some apps still running. Thanks.
8 REPLIES 8
MyNamesKrisG
Voyager
There is a "Never sleeping" apps option somewhere.
MyNamesKrisG
Voyager
adamlee
Black Belt
Set it as unrestricted
spikey1
Navigator
Can you explain? Thanks.
MyNamesKrisG
Voyager
Press and hold on any app, then tap the i to go to app info.
In app info, tap on "battery" and you should have three options, one of which is unrestricted.
MyNamesKrisG
Voyager
JAMES4578
Samsung Members Star ★★★
A bit about Sleeping Apps here, including the Never sleeping option https://www.guidingtech.com/how-to-manage-sleeping-apps-on-samsung-galaxy-phone/
MartynaK
Beta Moderator
Beta Moderator
@spikey1
I hope that the solutions proposed by other users (thanks to all!) will be helpful to you 😊.
