Where as Power share gone
(Topic created on: 30-09-2023 07:45 PM)
mikey15
3 REPLIES 3
DKZIE
Navigator
Should be still on your quick panel. Swipe down from the top of your screen and it should be there. If not you may have to edit your quick panel and add it back..Screenshot_20230930_225304_One UI Home.jpg
MartynaK
Beta Moderator
Beta Moderator
@mikey15
Power Sharing option should be available also during Beta.
If you cannot find it, please report the problem via the Samsung Members app 😉.
ladymarmalade
I can find it but it does not work
