Battery drain
(Topic created on: 13-09-2022 08:57 PM)
maciejireland
Pioneer
After more than one week with beta software battery start drain very fast. S21 ultra
4 REPLIES 4
adamlee
Black Belt
Beta 2 should be out soon. I'm not experiencing any battery drain but everyone's usage is different. Can you share a screenshot of your battery usage so we can further assist you?
nowdeleted
Big Cheese
I have not seen any battery problems with the 1st beta.
But I have turned off the adaptive brightness and lowered the screen brightness to a good level; also, dark mode is used.
GoanGeek
Samsung Members Star ★★
My battery has stabilised around 7 hours SOT give or take dependent on app usage and gaming.
I also do a wipe cache after each update and keep checking for app updates in both stores .
AnnaMaz
Beta Moderator
Beta Moderator
Hello @maciejireland,
As already mentioned in the thread - It's always good to perform Wipe Cache Partition as the first step in the troubleshooting process. And if that doesn't help, please report it through Samsung Members app so that the developers can take a look 😉
Have a good day!
