29-08-2024 12:49 PM
My phone has a problem where I receive or make calls and the recipient cannot hear me but I can hear them. When I hang up and call back, everything is okay. The problem is intermittent but very irritating.
can anyone help?
30-08-2024 05:46 AM
Has this just started happening @Stevie1908 or have you performed any software update recently.
If you perform a forum search you should find existing threads with some further help within.
You could try a network reset under Settings > General Management > Reset > Reset Network Connections.
There us also a diagnostic test tool found in your Samsung Members App.
Also a hard reboot may help > https://www.samsung.com/ph/support/mobile-devices/how-to-force-reboot-your-samsung-galaxy-smartphone...
The next step is > Clear Cache Files from the phone's System Partition Section > https://www.samsung.com/uk/support/mobile-devices/how-do-i-clear-the-cache-on-my-device/ You may need to insert your earphones or hook upto a powered On Laptop or use a Tv's USB Port to access the Clear Partition Section. This may help with lag or stutters as this clears the phone of old/unused or broken cache files.There is also a Repair Apps option in the Menu System too { Possibly excluding the s²⁴ Series of phone's }
If i can be of any further help please don't hesitate to ask 😎
Daily Driver > Samsung Galaxy s²⁵ Ultra 512Gb ~ Titanium Black.
I'm here to help. " This is the way. "
11-10-2024 11:35 PM
Thank you for the repair solutions. I have reset the network connections and that seems to have resolved the issue.
