Go to solution Solved
Is there a way to automatically turn on battery saver?
(Topic created on: 27-01-2021 09:04 AM)
galaxyIdo
Hi! Is there a way to automatically turn on battery saver with out bixby?
CrazyTom2k2
Helping Hand
Okay, on One UI 2.5, you'll need to go to Device Care > Battery > Power Mode > Adaptive Power Saving 🙂.
Hope that helps!
Tom 🙂
5 REPLIES 5
CrazyTom2k2
Helping Hand
Hey there GalaxyIdo!
If you go into Device Care, go to the 3-dot menu and select Automation, you should be able to turn on Adaptive Battery Saving. If you do that, your phone will automatically turn on Battery Saver if it reckons your phone will run out of charge before you charge it again. It's pretty smart. You can also tell it not to turn off 5G and stuff.
Hope this helps,
Tom 🙂
galaxyIdo
I don't see automation...
Phone: m31s
One ui 2.5
CrazyTom2k2
Helping Hand
Hope that helps!
Tom 🙂
galaxyIdo
Thanks for the help crazytom!
CrazyTom2k2
Helping Hand
@galaxyIdo no problem! Have a great night! 😁
