S21 standby battery drain in safe mode
(Topic created on: 10-02-2021 04:36 PM)
GizmoMKD
Pioneer
I have s21 exynoss  version. My battery is drained while phone is in standby...
 started the phone in "safe mode" then after 5 hours restart in normal turned on 4g to post the screenshot.
18 REPLIES 18
Stevar77
Same here s21 exynos, before AUB3 update had 48 hours with low use after update 30 hours. Today after full charge it's draining 5% per hour in standby screen off.
GoanGeek
Samsung Members Star ★
As a rule of thumb, always make sure location is only accessible by apps when their open bar a few.
Check your app permissions for location.
Also if you don't have good signal, it will drain battery as phone has to work harder to get signal.
google is normally the biggest culprit for background stuff, or some rogue app.
Follow Me, like my posts and Mark as Solution if I helped solve your Problems.
glavcevs
Same problem, after the latest Update, almost every night, s21 is losing like 40% in standby! AOD is off, Location is off, nfc is off, 5g is off! Before going to sleep, switched off all recent apps, but still drained!WTF!!!!?
GizmoMKD
Pioneer
There is new update around 250mb which fixed problem for me.
skyline91
This is my usage after AUB6 update. On the first picture before red lines it's usage with 3g and before update. Between 2 red lines it's usage after update with 4g . On the second picture i lost 7% with 9 minutes of SOT with 4g on and connected to wifi. I'll try to factory reset phone, but if that doesn't improve battery life ota update didn't fix bug for me.
Screenshot_20210213-141418_Device care.jpgScreenshot_20210214-121920_Device care.jpg
GizmoMKD
Pioneer
Try turning off volte if you have.
Weidan
are u on snapdragon or erxynos ?
tinglish
Hotshot
I have exynos,it's been brilliant to be fair 😍
Weidan
how is it on 4g or is it only on wifi that screen time ? 😃
