24-06-2021 09:07 AM - last edited 24-06-2021 09:08 AM
Hi!
So I've gone through all the possible settings guides, tips, cleared cache after every update, used galaxy booster app.
I also have the latest June update, really everything there is that can possibly help me get a better battery life (using FHD and 120hz which I won't give up).
Even got the phone company to provide me with a new Galaxy s21U since I've figured the first one was faulty.
After all that I still can't manage to get even 7 hours SOT (when I'm at home using WIFI no cellular data no Volte no 5G etc.)
Using standard apps like Whatsapp, Mails, Chrome , Facebook.
Usually I'm getting around 6-6.5 hours SOT and if I'm out of home using mobile data or god forbidden GPS, I'm getting around 5 hours SOT.
I really don't no what to do?! I've had an old Huawei Mate 10 Pro which had a 2 times better battery life.
12-08-2021 01:27 PM
Disable the fingerprint icon on the Always On Display. In fingerprint options, if you disable "show on AOD", that should correct the wakelock battery drain issue.
12-08-2021 01:38 PM
I am not using AOD at all and turned it off . Will the wakelock battery drain issue still be there ?
12-08-2021 01:47 PM
Set to never as seen below, ragardless if you use AOD.
12-08-2021 02:41 PM
12-08-2021 02:43 PM - last edited 12-08-2021 02:48 PM
Best to install gsam battery monitor to see if the problem with the drain issue is still there. I can however confirm that it worked for me.
24-11-2021 11:10 AM
It is useless to post a screenshot of batt.usage, you will find nothing intresting. All things on there are marked as 'good' by default.
I see a year long complains about this issue, with nothing done to solve this. The only thing I saw working is to root the phone and remove the samsung shell all together - but I'm not willing to do that yet at the moment.
So..... something in the samsung shell (user interface plus apps programmed over the android os) is draining the battery like a madman on steroids.
Samsung devs need to find out what that is.
24-11-2021 01:08 PM
