Go to solution Solved
Not showing WiFi connection speed anymore!
(Topic created on: 06-12-2023 05:43 PM)
Angelo005
Hi all, when u press and hold the wifi button from the drop down menu from the top of the phone, (shortcut) it takes u to the wifi networks available, when u go into the one u always use, it used to show u the Connection speed of ur phone to the router, now with this latest update, it shows ur password and security (WPA2) etc.... but it doesn't show the connection speed anymore!
That was a great help to me to know if my internet is running at the speed it should be. ie when ur connected to 2.4ghz the max connection speed is 144mbs, I'm on the Virgin Media 1Gb Super Hub which usually shows 1.2Gb, this is not download speed but connection speed, which is the speed of ur device to the internet Hub (if not on 1Gb) you'll probably see the maximum connection speed of 866mbps or lower, Well that's gone now! Any idea of how to get it back?
Go to solution
30 REPLIES 30
Lifeblood
There is an app in the Google Play Store, called WiFi Monitor: Network Analyzer by Alexander Kozyukov, that displays Transmit and Receive Link Speeds in real time, between your router and your device.  Just click on app, it should automatically open to the Connection tab, then scroll down to the Speed section.  There you can see your Transmit and Receive Link Speeds, and your Transmit and Receive Rates.
