Samsung WW90M645OPX/EU Smart Washer wifi issue
(Topic created on: 02-05-2020 07:48 PM)
MikeTeahan
I have a Samsung WW90M645OPX/EU smart washer and it was connected to my wifi and smart things for ages and then i notied that it said disconnected and would not connect. I deleted it from the smart things app and tried to reconnect it but it will not find the washer no matter what i do. I have pressed the smart control button for a few seconds until AP appears an use the smartthiing app to try to connect but it cant find it..
Strange this is when i open my router hub menu i can see it there as washer with an ip address and a MAC address, i tried pinging it and it worked...
Is there a reset i can do on the washer.. it said in the manual to press th etimer buttin for approx 30 sec while AP was on the screen to reset the wifi settings... i did this several times.. no joy..
It used to work, now i can connect it to apps..
Any help please would be appreciated..
Cheers
1 REPLY 1
nicd
exactly same issue. smartthings support couldn't figure out either. thinking it's the washing machine
