@Tiktok: An alarm may be sounding due to the following reasons:
1. The door is open: If the door is left open for more than 2 minutes, an alarm will sound and the alarm indicator will blink. You can toggle the alarm on and off by pressing Door Alarm. The alarm is enabled by factory default.
2. The temperature of the Fridge or Freezer is too high. The fridge should be set between 1 and 7 degrees Celcius, and the freezer set to -18 to -24 Celcius.
3. Auto Water Fill is overflowing
4. The water filter needs replacing.
Please check the display to see if any symbols are blinking that might relate to one of the issues above. If the issue persists, and the above isn't applicable, please confirm the full model number of the fridge freezer, and I will look into this further for you.
