RS5ON3513BC Loud ticking noise from freezer
(Topic created on: 09-11-2020 10:05 PM)
G15
Hi,
When the freezer starts (when the door is closed and the display switches off) it has started making a loud fast ticking noise.
It sounds like a pump, not sure what I should do? Do I switch the unit off and loose the food in the freezer?
Any help appreciated!
1 REPLY 1
CarloL
Hotshot
Hey @G15, if you can hear a ticking sound from inside the fridge, this is normal. It's caused by various parts of the fridge contracting or expanding in response to changes in temperature. If you are still concerned though, you can get in touch with the Home Appliances team either on Live Chat or by calling this number: 0333 000 0333.
