I need the thing inside the detergent drawer when using liquid in washing machines
(Topic created on: 12-06-2023 11:27 PM)
andy_in_ireland
Troubleshooter
hello all - I use detergent liquid in our washing machine and I see there is a thing that you are supposed to use in the main compartment when using liquid detergent , like a purpose made dividing piece of plastic , well I cannot find ours and was wondering where the best place I could get one from or buy one from ? - I live in Ireland.
thanks.
2 REPLIES 2
Hi mate, I couldn't find a detergent guide device for your machine but I did find something similar to the picture in the user manual. It apparently doesn't fit but it might be worth a try.
https://www.buy-spares.ie/liquid-detergent-guide/product.pl?pid=4674197 (This should take you directly to the Irish Buyspares website)
I didn't see any measurements on the device so you might be better off buying a dosing ball from Amazon. They do expand slightly after 60⁰C washes, annoyingly.
andy_in_ireland
Troubleshooter
great stuff thanks for that I will check buyspares out then
