Go to solution Solved
DV90M dryer door reversal
(Topic created on: 25-10-2020 03:15 PM)
JohnBrown_67
I am trying to reverse the door on my dryer. I have the door removed ready to reverse, but I can not remove the door front panel to reverse that.
I have removed the 3 screws and I am guessing it is clipped on the bottom half, but it is really tough and I dont want to break it.
Can someone verify it is just clipped and requires a good tug ?
AndrewL
@JohnBrown_67: I'm not sure about the force required to remove the front panel, however I recommend checking pages 22-29 of the user manual via the link below for a step by step guide.
https://downloadcenter.samsung.com/content/UM/201908/20190801175419820/DV5000M_DC68-03794A-05_EN.pdf
3 REPLIES 3
AndrewL
JohnBrown_67
Super star.
I did not remove the seal that was hiding 3 more screws.
Only took 5 minutes once I found them.
Thank you
AndrewL
@JohnBrown_67: That's great news. Glad I could help :smiling-face:
