Go to solution Solved
Drain hose on Samsung Series 5 WW90TA046AX/EU Bubble too short
(Topic created on: 20-03-2023 10:33 AM)
M131
Hi, l am hoping someone can help me. I have just purchased the above machine (previously had an Ecobubble machine and loved it) and waiting on it being replaced due to damage in transit but when it was originally delivered and they tried to instal it was discovered the drain hose was to short to go into the connection under my sink. I did ask Samsung when l was returning the washing machine if they could supply a longer hose but they weren’t very helpful and l looking for some help if anyone else has encountered this problem and whether they found a workable solution. 🙏 Thanks Marion
andy_in_ireland
Troubleshooter
you need one of these:
Then a hose:
3 REPLIES 3
andy_in_ireland
Troubleshooter
Then a hose:
M131
Thanks Andy, that’s a great help.
Nick50000
I have the same issue. Can you help with what diameter of connector I need! I bought one that was supposed to be 19mm internal and it was too small to attach to the existing Samsung hose.
