Digital inverter WM motor issues?
(Topic created on: 05-02-2024 01:02 PM)
I have this problem too
shawnb1
Hi. Our WW90J6610CX/EU washing machines drum will not turn, when turning on the machine the program empties the water and fills up but the drum will not turn, the machine basically stops. The drum turns by hand and the belt is not snapped. No issues are found with the codes when scanned into the app.
The machine warranty expired 6 years ago but the motor has a 10 year warranty?
Help please!
2 REPLIES 2
Lynnez
Hi I have identical problem as you. Could you tell me what the outcome was please.  Lynne
andy_in_ireland
Troubleshooter
inverter motors very very reliable, go on and on for years thats most probably why they offer 5 and 10 year warranties on the motor itself - its more than likely the motor controller board , sometimes the capacitors go on them , but the boards on samsungs a lot of the time are covered in some kind of resin glue which makes replacing parts on the circuit board very difficult
