03-02-2024 12:48 PM
03-02-2024 02:41 PM
Hi @Gez14
If you tap on the graph, are there any apps or features in particular that are using up more battery than usual? If so, we'd definitely advise either ensuring the apps/features are closed when not in use (by tapping on the 3 lines in the bottom corner > Close all), or getting in touch with the app developers.
If it's a Samsung app, please get back in touch with more info!
03-02-2024 02:46 PM
03-02-2024 03:57 PM
No worry at all, I'm here to help!
Are you able to share a screenshot of this page, when viewing the apps that are running during the major battery drain?
03-02-2024 04:11 PM
12-04-2024 04:09 AM
Hi.
My samsung z flip 5 is draining suddenly at a very fast pace after the 6.1 update.
How do I roll back the update?
03-05-2024 02:41 PM
From the screenshots shared, there doesn't seem to be much of a battery drain. Is this a constant thing you're experiencing? How often would you say the battery drains?
03-05-2024 02:56 PM
Hey @Sukriti
Are you able to share a screenshot of the battery drain? You can check this by heading into Settings > Device care > Battery > Tap on the graph.
16-05-2024 09:28 AM - last edited 16-05-2024 09:29 AM
24-05-2024 04:27 PM
It looks like a lot of people experience the same issue after UI 6.1 update, I hope they fix it soon.
