Diagnostic battery issue
(Topic created on: 23-04-2022 05:06 PM)
JeffreyDS
Has anyone come across this issue, ive had the samsung galaxy fold z3 since release date and had minor battery issues but over a 9hr work day (with maximum 40 mins usage on breaks) I go from full charge to 59%.
1 REPLY 1
llaadd5
Samsung devices have 2 year warranty and the batteries i think 1 year so best to contact support, they may be able to come to you to repair under warranty.
But also worth checking apps which may be running in the background, check:
Settings > Notifications
Also check
Settings > Battery and device care > Battery
Now click the graph and it will how what apps are draining your battery and by how much, you can then go into the apps and disable notifications etc to reduce their impact.
