S25 Ultra Bluetooth audio cutting out after recent samsung updates
(Topic created on: 01-04-2025 12:48 PM)
Members_3sPWmq3
As of today bluetooth audio keeps cutting out after about a minute of playing. The only way to get it working again is after completely rebooting the phone, but after about a minute of playing audio it cuts out again.
This started happening after some recent updates to samsung and android system apps.
I have found multiple people online having the exact issues as of the past couple of days, so please don't start following some script with with factory reset as something to "try" - I bet my life on it that this is a reproducable issue.
-edit
Found out it is also happening on the S24 series since the past couple of days.
14 REPLIES 14
Members_caxRQt1
That's strange if it is, I used my other work phone to try if it was a car issue or not,its a Samsung s20 or something. So it only happens with new phones?
Members_ryLcUFH
Dit geldt precies hetzelfde voor mij. Ik heb namelijk 2 BMW's en op beide ervaar ik hetzelfde probleem. Ik heb dan het gelukt dat ik dan bij de 3 serie wel Android auto heb daar doet die het wel op.
This is exactly the same for me. I have 2 BMWs and I experience the same problem on both. I have been lucky that I have Android Auto on the 3 series, it works on that.
Members_ryLcUFH
Je hebt gelijk! Ik had al zo'n vermoeden dat er vertraging zou optreden vanwege de update. Flitsmeister is op dit moment op de hoogte van het probleem.
You are right! I already suspected that there would be a delay because of the update. Flitsmeister is currently aware of the problem.
Members_3sPWmq3
I didn't look if they patched it yet, but I found out the problem originated in de lowering of music volume when flitsmeister sends an alert - if you disable this volume lowering function the issue won't trigger.
And yes, at least android auto was working, but I actually prefer idrive 7 and the bmw navigation. Also my dash screen (behind the steering wheel) doesn't show the minimap with android auto (nor album art).
akanbaz
The issue is because of WhatsApp. Force stopping the WhatsApp resolves the issue temporarily.
