Battery drain 2
(Topic created on: 09-02-2025 04:37 PM)
Bharwah
Voyager
So I did a previous post about this apologise for another one but this isn't right , first day 12h , 2nd & 3rd day around 9 hours and today only 3 hours of screen on time im at 27% for only 3 and half hours ... yeah I did smart switch for my apps and pictures and files
18 REPLIES 18
Piper123
Samsung Members Star ★
But you are getting it.
I get around 12 hours of screen on but only about 18 screen off.
You are getting (scaled up) about 4.5 hours Screen On but almost 48 screen off
S24 Ultra
Sonora
Black Belt
Always download apps from Google Play or Galaxy Store, never via Smart Switch, that's an old problem, old apps are not optimized for your device and can lead to higher battery consumption. In the worst case, you can do a factory reset and download apps fresh (if you have a Google backup, all app data is there), and use Smart Switch exclusively for photos and files
Bharwah
Voyager
OK kl so I should do factory reset and only use smart switch for files and pictures
Joeeye
GrandMaster
No not at all. Your off screen usage could be vastly different to another users based on devices connected, phone signal, mobile data usage, dual SIM etc. It's not a one rule fits all situation.
Deeplay68
Pathfinder
I have ram plus set to off, but have not really configured anything else and do notice my battery life is improving from what it was a week ago. Going through the day no charge needed, of course it depends on what you are using. I dont game at all. But heavy use of email apps, browser, messenger and quite a lot of YT and Netflix viewing over this weekend. It does learn and improve over time I think give it a while longer before considering hard reset.
S25 Ultra 1TB - S23 Ultra 512gb - Galaxy Book3 Pro 360
Bharwah
Voyager
OK thanks , and same here I use it like you do
Sonora
Black Belt
Factory reset is the last thing you should do. But I think your battery is still learning, mine on the S24 ultra only improved after a month
Bharwah
Voyager
How many hours of screen on time you getting ? And do you use 5G
Deeplay68
Pathfinder
i dont count but going full day with 20  / 30 percent left - depends on usage. I use 5g when outside but wifi when not.
