Zavřít
zrušit
Zobrazování výsledků pro
Hledat místo
Měli jste na mysli:
Přejít na řešení VYŘEŠENO
Původní téma:
Small gap between display and frame
(Téma vytvořeno: 02-02-2024 12:19 PM)
7398 Zobrazení
Smoukyy
Možnosti
I've just bought s24 ultra in orange color and everything is great. But today I noticed there is like 0,5 mm gap between screen and the titanium frame. I know on the top of the screen there is a speaker at the center so thats not the gap Im referring to. On the bottom of the phone screen is perfectly aligned with frame of the phone and in top right nearly perfect too. The issue is with top left side where I can see tiny gap between screen and frame. Should I apply my warranty or what do I do?
2 Řešení
Přijatá řešení
Řešení
23PeterK
Samsung Members Star ★★
Možnosti
Hello.
I have the same gap on my S24U (orange color)...
Zobrazit řešení v původním příspěvku
Řešení
TomiXL
Možnosti
Hello,
it's completelly normal and for optimal operation of your device, a slight display gap is necessary. The construction of the phone have to last in diferent weater conditions and must withstand some bending during manipulation with the phone. Different units can have slightly different gap between display and frame but all units have it. All display gaps are placed following strict internal standards and does not affect the performance or function of the device. Additionally, Galaxy series that are water and dust resistant are constructed to block liquids or debris from the internal parts of the device. So, you don't have to worry.
8 Odpovědi
Ultra92
Helping Hand
Možnosti
The gapScreenshot_20240202_124941_Reddit_1000029842_1706874582.pngScreenshot_20240202_125938_Chrome_1000029845_1706875192.png
Řešení
23PeterK
Možnosti
Hello.
Smoukyy
Možnosti
Just a tiny gap like me? Are you going to do something with it?
23PeterK
Možnosti
I have small gaps on the bottom left AND right side. Both similar size
Wlado265
Voyager
Možnosti
I have the same gap, but i had to use light to even see it, and honestly its just a phone, which is working and gap is invisible, Im not event telling that everybody will use some type of case, with my spigen its completely covered.
Smoukyy
Možnosti
Yeah it is idk why but it annoys me even when it doesn't do anything bad
Řešení
TomiXL
Možnosti
Hello,
Smoukyy
Možnosti
Oh thanks for that
